Price???
The preferred price isn't that bad on the 0w-30 all things considered.
Looks like the mid-SAPS and low-SAPS chemistries are significantly more expensive than the older full-SAPS chemistries that a lot of folks love.
Only their 5W30 (AEL) has the VAG 504/507 approvals.The preferred price isn't that bad on the 0w-30 all things considered.
I assume no real 504 approvals.
Baby steps...Again, one of those: We know better than manufacturers what kind of approvals they specify; therefore trust us when it comes to their specifications.
Castrol is doing the 3.5 HTHS “suitable” for FE also. But yeah, the spec combination is strange.10W60? WOW, catching up 20yrs later.
As for 0W30:
LL01FE but HTHS 3.5?????????
LL01FE but also MB229.51/52, VW504.00/507.00?????
I think that genuinely they are trying to scam customers.Baby steps...
Suitable after having actual LL01 listed.Castrol is doing the 3.5 HTHS “suitable” for FE also. But yeah, the spec combination is strange.
Well we should give them a break. LL01FE does have a max hths of 3.5 which I always thought was odd.10W60? WOW, catching up 20yrs later.
As for 0W30:
Arguably, their concoction probably passes most of the LL01FE tests but fundamentally doesn't qualify since it may or may not meet the fuel efficiency standards.I think that genuinely they are trying to scam customers.
Maybe, but OTOH we have ACEA C3 M1 ESP 5w30 with a HTHS of over 3.5 and it meets FE requirement under C2.Arguably, their concoction probably passes most of the LL01FE tests but fundamentally doesn't qualify since it may or may not meet the fuel efficiency standards.
LL01FE is full SAPS oil. There is no oil on the market that has LL01/LL01FE in the combination with MB229.51/52, VW 504.00/507.00.Arguably, their concoction probably passes most of the LL01FE tests but fundamentally doesn't qualify since it may or may not meet the fuel efficiency standards.
That is easy to speculate on their part when oil is not approved. You can throw on the paper anything and say: wel…Well we should give them a break. LL01FE does have a max hths of 3.5 which I always thought was odd.
