New 05 RAV4 AWD A/T..... filter ideas?
Pittsburgh area
Hello all, great forums, tons of inetersting info... Have a question please;
Coming up on the 1st break-in oil change, (2K miles so far, but just want to get some clean oil in there) and was going to go with recommended 5W30. But going to use Full Synthetic oil.
Anyway, I looked at the filter - it is this itty bitty little "soup" can.
I worry about the tiny size of the filter; does anyone know of an "upsize" filter that I can use on the RAV 2.4 engine instead of the "stock" size?
Thanks all in advance!
Steve in PGH
Good luck! Hopefully!
Id suggest you get some LC and use it maybe after 5000 miles or so. It will keep the insolubles low, so even if there isnt a filter like this, things will be fine.
JMH
Try to get the Toyota Denso 90915-10004 made in japan oil filters, they are the yellow foam element type. In japan, it has superseeded all the paper element type.
denso first time fit filters are my favorites for toyota... nippon filters are pretty darn good too... available from any online parts discounter.
but I dont know much about your engine, etc.
JMH
Or if you're feeling rich, you can try the japanese made TRD oil filter for the AZ series 90915-SP010. TRD claims this filter filters away 45% more gunk.
4967 is stock.
4386 is same diameter as stock but longer.
3614 is toyota's V6 size filter.
3600 is the oversized version of that (same diameter, but longer)
also works is AC Delco pf53 and Motorcraft FL-400S
Toyota engineers know your engine oil flow charectoristics and needs better than anyone on this board. I personally would have confidence in their recommendation.
Steve,
In the case you have anything go wrong on the engine, Toyota will cause you some problems if you use anything other than what is spec'd for the outfit (Nice ride BTW
The "small" filter is all that is needed and works quite well. I'd recommend (and do with my own 2005 Toyota) that you stay with the correct oil filter.
I've used Toyota, Supertech, Bosch, STP and now trying Purolator and they all work well. The used oil analysis come back with everything looking great so it's doing a good job.
I'd also recommend that you go ahead and change the oil and filter out soon but go with a conventional or synthetic blend and if you want to go syn (with 6m or 5k miles MAX OCI you'll not need a syn) wait till 5k miles.
My toyota used more Mobil 1 oil durning it's 5k run with it than any other oil I've used so far and the used oil analysis showed that the cheaper oils protect just as well for a LOT less. Also the MPG was the same as conventional oil.
I've got quite a bit of on sale oil and the Toyota seems to like any of it.
Take care, Bill
Purolator now makes both their Pure One PL14477 and Premium Plus L14477 as a direct replacements for the 2005 RAV4's oil filter now, Steve. Same size as OEM.
Earlier this year, the Premium Plus wasn't available, so that's a new fitment from Purolator. I'll be running P-Plus when my stash of Toyota filters runs out.
Might also want to score a couple of these:
http://www.filtermag.com
The SS-250 is the model you want. Get two of them, for full wrap-around coverage. Order one, and you'll only cover half the filter wall.
Do they work? Yes. Got 'em on my 2004 RAV now. I've cut open several OEM filters so far and have seen first hand how much stuff is collected on the wall of the filter. To me, especially with a filter this small, anything to keep the media flowing and metal out of the oil seems like a good idea.
Search the Oil Filters section of this forum for "Oil Filter Cutter" if you want some ideas on getting inside your filter. I have the Tavia 08340 cutter, available from:
http://www.globaltoolsupply.com
(Search on Tavia 08340)
The Tavia unit is expensive, but is very nicely made. There are other cutters for less money.
And here's a great RAV forum, btw:
http://rav4world.com
Enjoy the new ride! And welcome!
Use the same one that came with the factory-fill oil until the warranty expires. If staying with conventional oil, I would stay with the brand the dealer uses.
Just my opinion!
Hey Steve,
Have an '05 RAV4 L myself. 600 miles, two weeks old. Have you done your initial change? What did you go with? I have a NAPA Gold 1396 waiting here. All I need now is to choose an oil.
IslaVistaMan,
I just ordered a set of filter magnets. Love the simplicity. Pricey, but ... worth it for peace of mind. Thanks for sharing!
Thanks, kj
