A few months ago I picked up a cheap Craftsman snowblower on FB marketplace. It's a weird one, has a vertical shaft 3.8HP Tecumseh with a belt drive to the single stage auger. The engine ran great, replaced spark plug and changed the oil (looked like it had probably never been changed) with Super Tech 5w30 HM. Spent $50 for a new auger paddle kit since the ones that were on it were totally worn down, and bolts, nuts and washers to attach it (since the original ones were riveted on), It worked perfectly, ran great. I got two good uses out of it. Today I go to start it this morning, and it doesn't want to stay running without choke on. Sigh, carb is gonna be clogged up, pull carb bowl off, clean out the dirt. Then, I realize the bowl gasket is dry rotted as heck, and cracked. I try to put it on, think it's fine, then use it for about 45 minutes.
Hours later I go to use it again, won't start at all now, and now I see gas pouring out the back of the carb bowl. ****. Pull it off again, it's not broken in half and there is no way to get it to stay in. Ordered a rebuild kit from amazon but it won't arrive till Monday. At least I got most of the snow this morning, but ugh, I should have done it months ago. But it was running great and wasn't leaking so I didn't worry about it. That it seems was a mistake.
It's one of these weird ones. Worked excellently until it didn't. Moral of the story? Don't trust old tecumseh carb gaskets.
