Never changed trans fluid before.
Even if you don't spill any fluid, you still have to account for clingage (or transfer) losses to figure how much fluid to refill.
I actually prefer to drop the pan at least every 50k or so to wipe all of the clutch material out of the pan - something you cant do with a flush alone. and while its true that many transmissions now use screens instead of real filters, I fixed a late 80's Cavalier that had shifting problems - due to a clogged filter - it dropped the pressure enough to cause problems downshifting on hard stops.
Originally Posted By: mechanicx
Originally Posted By: Drew99GT
With the help of 1 or 2 other people, you can disconnect the lower trans cooler fitting at the radiator, screw in the correct size AN fitting with a hose barb and stick a long length of clear plastic tubing into a jug with a small opening. There's a fill plug on the top of the trans, so with a long funnel, you idle the engine in drive while continuing to fill the trans, you'll pump out the old fluid and it'll be refilled with new fluid.
There's a another plug on the side of the trans that you open to measure the fluid capacity. When it's at operating temp, refill the trans until fluid comes out that side plug hole while the engine's idling in gear and the fluid level is then correct.
That's what I did on my Grand Am. It was a messy endeavor, but worked!
This is the way to flush the system out. do you remember what size flair fitting the cooler is? Did you check the level at the check plug on a lift or could you get to it on the ground?
That was 6 or so years ago so I have no clue what size the fitting was. I did it with the car on jack stands to be able to get far enough under to the check plug on the side of the trans.
So i am on my phone waiting for the trans to be serviced. Looks like some of you were right, I asked about the fluid used and for this car DexII : ( I requested dex vi which they said was fine but they seemed a little surprised, maybe even annoyed. Lets see if they charge me more! ; )
I recently did the auto trans in my 2000 Tacoma, 140,000 miles. I dropped the pan, cleaned the filter & magnets & put on a new gasket. I was going to put in a new filter but not in stock at the parts store. Yes the fluid that came out was a little 'tired'. All is well now & no leaks. Better a little late than never.
