Walter1982
Interesting. There's so much to know, and if you are not well informed the dealerships treat you like an idiot and will not divulge crucial information. A year after buying the car I found a TSB for a firmware update for my IVT, the update apparently eliminates the "slip" or "drag" from the IVT upon accelerating from a red light. I vaguely remember it being an improvement for me.There are a set of values stored on a module on the valve body in the CVT. These values can be cleared and then will be read / programmed when the system is re-started. I did that a few times when I was swapping TCUs but I never noticed a difference.
In our car (Nissan Cube) I've used three different TCUs with two different CVTs. It's all plug-&-play as far as code goes, wish it was so easy on the mechanical side. The most important thing is having the firmware up to date and keeping the fluid & magnets clean.
For now as long as I have a way to monitor IVT fluid temperature I think it will be good enough for a drain/fill. Maybe sometime in the future I can figure out how to reset adaptive values. Someone in the Kia Seltos forum uses a THINKDIAG scanner that's under $200 that allows him to reset adaptive learning values. There's also a $550 scanner computer that may provide even more features.
In the Seltos forum I learned of a place for service manuals called "factorymanuals.net" and I emailed them and they said the manual for the 2020 Kia Forte has information on removing the transmission pan for my IVT, which should have torque specifications and tightening sequences. It's only $70 so I will likely buy it, which will allow me to open the pan and clean the magnets at the very least. Someday I may determine if I need to change out the filters as well. The IVT fluid is only $15 a quart, and each drain/fill will use about 4 quarts, so I will drain/fill this month, and later in the summer I will clean the magnets and obviously drain/fill again. I have a 3 year subscription to ALLData DIY service manuals, but for my Forte it does not have the procedure/torque specs for the IVT.
From what I've gathered reading about my generation of the Forte, it seems the IVT's start to fail in expensive ways before the engine does. Since I've always religiously changed the oil, I'm now extra focused on the IVT, and would like it to last just as long as the engine. It's taken me quite a bit of time to gather the necessary information to confidently work on the IVT.
