my 1995 Saab 900se 2.5 v-6 automatic. Has the chck gear box warning light come on on the display screen. The transmission will only run in 3rd gear and reverse. no 1st 2nd, no kick down. The saab forums advise to replace the neutral saftey switch on the transmission it is connected with a cable from the shift lever inside the car. I installed a brand new neutral saftey switch. the same warning light is on and the transmission will not down shift it stays in 3rd or reverse. it is so bad I had to back up the drive way in reverse as it would not pull ythe slight grade in the ony forward gear i have third. Any ideas guys thanks
![frown.gif](https://bobistheoilguy.com/forums/images/graemlins/frown.gif)
