I've got about 15 hours run with ARX on a 1985 CASE Skidsteer with 4000 hours on it. I'm checking to make sure I could put Neutra in the diesel before fueled it up today.
The ARX is doing a good job cleaning up the rings increasing compression and power. I can see the difference when I raise the bucket. Before I added the ARX the bucket would not lift out of the dirt if I took too large a bite. The engine would just grunt, and I even stalled it once. After about 10 hours of ARX treatment the back of the skidsteer started to lift off the ground when the bucket bite was too much to lift.
The engine vibration is reduced considerably, and the low speed idle is much stronger. The engine did start to surge at mid rpm after about 6 hours of ARX treatment. I have heard of this happening as ARX starts to work.
I did not remove the pan as this engine has had a very good service history and I don't know much about it mechanically. It had a recent oil change and I have not noticed much color to the oil, just performance from the engine.
I also dumped two bottles of ARX in the hydralics, and one seal that leaked has stopped leaking.
Now I figure it's time to put molecules FP/Neutra mix into the diesel, or maybe straight Neutra. It's a 15 gallong tank, and at 1/4 tank I it'll take 10 gallons to fill.
