Frank
Member
Member # 34
posted June 12, 2003 08:44 PM
How It Works.
Rick20
Member
Member # 196
posted June 12, 2003 04:36 PM
Auto-Rx is more than just a cleaner. Sure it is sold and marketed as a cleaner. However its made up, primarily, of three esters. One being a naturally occuring fatty alcohol, esterified, which serves as the primary cleaning component of varnish and combustion contaminants. It also contains a polyol ester and an aliphatic ester in it formulation. These little animals were added to give the product properties of enhanced ep and a foundation resistant to oxidation. These are good properties to be added to the package when cleaning a motor. One of the secondary esters is primarily used in aircraft lubrication, the other is a chlor free, phos free, boron free, friction reducer, primarily used in metal fabrication, be it stamping, machining, to keep friction down when heat can be the difference in a good part and the scrap bucket. These are a couple of good allies when removing third party abrasives from your motor. Drive on.
Posts: 62 | From: North Carolina | Registered: Jul 2002 | IP: Logged |
