Originally Posted By: grampi
Originally Posted By: Jarlaxle
That is the attitude of the typical "Toyotas are perfect" drone...the car is an oil guzzler, but thats fine, because Toyota says it's "normal". Unbelieveable.
Ask any mechanic and he will tell you it's completely normal for ANY engine to use a qt of oil between oil changes...an oil guzzler is an engine that burns so much oil it smokes when going down the road and/or fouls out spark plugs...and I would put any Corolla or Civic engine up against any domestic engine in that segment in terms of reliability and engine life....I'd like to see a [censored] or Neon motor go 300K without ever having the engine apart, still with the original water pump, altenator, etc...
No, he won't...well, unless he just rebuilt the engine and doesn't want to admit he screwed the pooch! With over 185,000 miles, my Jeep (4.0 HO) uses NO oil. (Less than half a PINT in 5000 miles!) In 80,000+ miles, I had to add oil to my Magnum (Hemi) once...it used about a quart and a half in the first 5000 miles, nothing at all after that. Liz's Festiva (carb'd 1.3) used less than a quart between changes (4K, usually) with 270,000 miles. My truck (Cummins 5.9) uses less than a quart in 5000 miles.
If a Civic has the original WP at 300,000 miles, the owner or mechanic is an idiot: that's a changeout item when doing the timing belt! (Same is true for a Neon, actually, though at 100K.)
I understand you feel the need to rabidly defend your oil guzzler...but Toyota or not, it's still an oil guzzler!
