My brother's '95 Cutlass Supreme with the 4T60-E transmission has started to weep very badly at the transmission pan gasket. I've done the repair before on my '97 Grand Am with the same trans (very easy job to change the gasket and filter), so the job itself doesn't really concern me. What I am wondering, though, is what fluid to use. Currently, the vehicle has 195,000 miles on it and, to my knowledge, the transmission fluid or filter has never been changed, only been topped up when needed because of leaks. The transmission itself still works great, no slips or flares. The manual specs Dex III, so I could use that. Dex VI supersedes Dex III and could also be safely used. Then there is the beloved MaxLife. I used maxlife at 165,000 in my 4T60-E equipped Grand Am and it worked a treat. Actually, the trans worked extremely well on anything...
The reason I debate is because the transmission is obviously high-mileage. The originally specced Dex III fluid is a little thicker than my other 2 options, at around 7.5 cst. The Dex VI and the MaxLife (which is a little thinner like the Dex VI) are around 6.1 cst. Would the thinner fluid work fine in an older car like this? Like I said, it worked well in my Grand Am, but it wasn't quite this high-mileage. What say you?
