I am approaching the 2,000 mile mark on my 2001 VW GTI 1.8T since the first oil change of me owning the car. I am now in need of some guidance on what to do next.
Please refer to my previous thread for more information/pictures = https://bobistheoilguy.com/forums/threads/cleaning-the-vw-1-8t-questions.131985/
It is currently filled with Shell Rotella T6 5w40. It has not burned any oil or leaked any oil since I put it in the motor. The oil is a darker color at only 2,000 miles, which tells me it has done some cleaning to the inside. If there are particles floating around, I want to get the oil and filter out ASAP to avoid any problems.
The inside of the motor, from the oil fill cap, looks the same. I can't tell the difference. I am not taking off the valve cover to get a better look.
The motor runs smooth and has not given me any sort of problems. Always starts up and performs fine.
All that said...what should I do next?
A simple oil and filter change with T6 and run a 3K or 5K OCI?
Run some sort of solvent?
Try a different oil?
1. Vehicle: 2001 VW GTI 1.8T
2. Manual: 5w40 or 5w30 API SJ
ACEA A2 or ACEA A3
VW502 00 or VW500 00 or VW501 01
3. Location: Cleveland, OH and Erie, PA
4. How you drive: Easy with the occasional spirited drive
5. Daily drive: 60% city 40% highway
6. Problems: No known problems. No leaks. No oil consumption.
* I just want an oil that will protect my motor, keep it clean, and I can run year round encountering temps from 0*F to 95*F.
I have read people using 5w40, 5w30, and 0w40 in the 1.8T motor. I am unsure on what to do in my application.
I need some guidance! Thanks for your help.
ACEA A2 or ACEA A3
