Originally Posted By: partspro
Considering all the issues with this motor I wouldn't use anything other than factory recommended. My buddy is a factory trained VW/Audi Master Mechanic and after reading all the internal Audi documents he switched to M1 0w40 for his personal A4 turbo. He seafoamed the engine before switching. He previously used Castrol Syntec 5w40.
The biggest issue VW had with these 1.8t motors is the reduced sump capacity in longitudinal installations and owners who went 5-10k on a oil change using conventional oil. I have not seen a sludged up 1.8t that ran synthetic and 5-10k OCI's.
Rotella T6 5w-40 will work fine in a 1.8t. These 1.8t engines got a bad reputation from mainly ignorant owners who could not be bothered to read the owners manual. Granted some VW dealers did not help the cause and used bulk 5w30 they had on hand. And the early AEB models had a pretty failure prone timing belt tensioner. Overall the 1.8t VW engines are pretty tough and durable, any syn 5w-40 will work absolutely fine.
