Originally Posted by OilUzer
Aren't High Mileage oils typically on the thicker side of the spec? Just curious if adding the liqui moly can completely get you there!
Also OP wants the thinnest 5Wx30 High Mileage. Doesn't that defeat the whole idea of using High Mileage? I don't use High Mileage but was under impression that they are on the thicker side of spec as well as higher hths! No? so a thin thick doesn't make sense
A well formulated normal non-High Mileage oil has everything you need except maybe (for older engines) a little extra seal conditioners that High Mileage oils market to you.
Sure, some High Mileage oils are a little on the thick side, and some aren't. For example, Valvoline MaxLife Full Synthetic 5w30 kv100=10.1, and silver bottle Mobil 1 5w30 kv100=11.0, so comparisons vary depending on which brand of High Mileage vs. normal non-High Mileage oil you compare to each other.
For winter, it can be good to look for the thinnest KV40 you can find within your engine's spec recommendation, as it should deliver something that flows better cold on typical 20 degF mornings. ...
------If you're thinking down at super-cold temperatures, then a "0w" is probably is what you should get, like Mobil 1 Advanced Fuel Economy 0w20 or 0w30 is a good choice when its really super cold.
