Wow, night and day difference. No more lean stumble/misfire at all that I can tell. Amazing that the older pilot jet passes more fuel than the 2024. But maybe not really, since this is where the EPA/CARB is strictest on fuel mixture, and probably tightened it down more for 2024. They always put it on the ragged edge of lean and seal it up so folks can't adjust it to make it run properly. They fear that someone will mess it up and run so rich they wlll have a cloud of greenhouse gases hovering above them making mini climate change.
Anyway, glad you fixed it. See? You can do it. Just takes a little figuring out and some cursing while trying to get things apart. Now, to work on your YouTube videos.
Indeed. I can guarantee you that it is totally reasonable too. There is no visible smoke and no appreciable smell… I am in the same camp as you that a small engine burning 1.2 gallons of gasoline in 10 hours is not going to contribute even the most trivial amount to climate change. It is kind of like the auto off feature on my vehicle … saving a teaspoon of gasoline every fill up is not going to save the environment
