Thank you. The fuel is not exposed to,the outside. The holes must go through the screw through the sides. I will see about getting a video perhaps tomorrow.Good deal, and good fix! Surprised the screw has a hole in it and is exposed to outside, unfiltered air. To me that would subject it to something getting inside and plugging it up. Well now that you know how it all works, if it starts running rough, or lean misfiring again, start with cleaning out (or heck, replacing for that price) the jet screw. Seems like this is where the problem was, and not necessarily dirt or a clog, but just not big enough to deliver sufficient fuel. Again, good job!.
I just changed the oil again. It is at 4.2 hours on its Hobbs meter I added (the Hardlone hour/tachometer).
I still hve to run it through the gambit and finish the break-in with varying load.
