Specifically, a VSX-84TX Si. It has the ability to re-purpose the surround-back channels to bi-amp the front speakers (along with the regular front speaker channels). Somehow, this option is not working on the receiver I am working with.
The receiver is supposed to send full-range signals to all channels in the bi-amp configuration, so it doesn't matter how the front speakers are hooked up. Currently, the front speaker outputs on the receiver are connected to the low-frequency inputs on the front speakers, and the surround-back outputs are connected to the high-frequency inputs. The problem is that, in this configuration, the front speakers are only playing low-frequency sounds, as if the front channel outputs are working but the re-purposed surround-back channels are not.
I verified that the speakers and wires are connected and working properly by setting the surround-back mode back to "Normal (SB)" (for 7.1 operation) and playing test tones on the surround-back channels with the surround-back outputs still connected to the high-frequency inputs on the front speakers. In this configuration, a test tone on either front channel still produces low-frequency sound from the corresponding front speaker, whereas a test tone on either surround-back channel produces high-frequency sound from the corresponding front speaker. Exactly as it should be. This makes me think that the problem with the bi-amp mode is a configuration issue on the receiver.
Any help would be greatly appreciated. Thanks in advance!
