I’m looking for this type of rigid plastic vacuum line but I’m not sure where to find it or what’s it’s made out of exactly. It’s 14mm OD x 11mm ID . I need to lengthen that section between the brake booster and check valve. I would like to use the same type of hose so it won’t collapse under vacuum.
