Originally Posted By: tomcat27
Originally Posted By: cb_13
Why would the use of aluminum have anything to do with using green anti-freeze? It was original fill in many vehicles with aluminum heads and radiators. I do prefer the G05 myself since it's a long life formula.
because aluminum is much more susceptible to corrosion. while certainly standard green inorganic coolant was used with aluminum heads, as automakers gained more experience and as they continued to include more aluminum and other metals in the cooling system - they switched over to organic acid coolants and HOAT coolants. (commonly called "long life")
there are also challenges with mixing long life coolant with traditional green coolant - you really want to flush all of the old out - as mixing the two will reduce the effectiveness of the new - and some of the anti-corrosion ingredients can actually precipitate out. You may also find some manufacturers who specify HOAT over OAT because of water pump seals. (Chrylser, Cummins)
I had always been led to believe that silicates were the best protection for aluminum parts. Which is why the G-05 formula also included silicates. The issue was with the fact that the old green needed checked for PH and electrolysis, have SCA's added and/or be changed at a more frequent rate. I'm not stating this as a fact. That is just what I had been told.
I certainly would not mix types if at all possible. Ive seen the goo that a mixture of the early version of DexCool and green can turn into over time.
