I've done three Powerfoam soaks on my XC70's cylinders over the last month, and have had great success so far. The car's running like a striped ape now, and I couldn't be happier with the results, plus the installation of PU afterward is awesome.
The XC70's cylinders are fully vertical being an in-line five, so it was easy to ensure a thorough soak to the piston heads.
My question is about my old Trooper's V6.
The banks are angled, so I'm only able to saturate the lower portion of the cylinders and piston heads because of the bank angle.
The Trooper's been soaking for two days now, and I'll clear it all out tomorrow. But I know that only half the carbon build-up on the piston heads will come free because of the angle.
Any ideas on how to thoroughly saturate the entire cylinder and piston head on a V engine?
I guess I could flood the cylinders completely with Powerfoam, but I just don't have that much Powerfoam to go around, plus it'll probably bleed out around the rings.
I was thinking about using a pressure washer to spray high-velocity water into the cylinders and then sucking it all out, but I'm working in a parking lot with no electrical or water resources available.
Thanks.
Thanks.
