Need AC adapter
ME
Have a generic AC manifold set. Its yellow hose input takes what seems all the world like a male 3/8-24 brake line nut with a bubble flare (actually a 45 degree angle.) Also have some home AC adapters that take the same thing in 7/16-24.
Have a r134a can tap that has a 7/16-ish (actual diameter, nominal 1/2") ACME male thread output.
What do I need to bring these two together, and, bonus question, why are they trying to not let me do this?
Further research indicates this might be accomplished with an R12 to R134a adapter. R12 is not at all involved in this, want to charge a 134a car. Are the manifold hoses still threaded with obsolete tech just because that's how it's always been?
I had something cheesy like that but it stopped passing gas (hah!) and since I have a "real" manifold I'm trying to do it "right."
I think one of these adapters will accomplish your objective:
R-12 to R134a Coupling Adapters
^ That's about what I wound up getting locally at NAPA for $16, sheesh, big markup for them. P/N for posterity: 78-3199/ NTE 783199 ADAPT 1/2ACMEFX1/4MFL "you sir are a mouthful."
Works great, got the kid's Prius down to a 43' vent temp in 70+ dewpoint swampy air.
Only question remains, why do they sell stuff that doesn't fit with other stuff that you'd expect to go together?
The 3/8 thread (flare for 3/16 tubing size) was used on the high side of later R-12 cars so people couldn't put their basic cheap can hose on the high side by mistake.
All the fittings were changed for R-134a to discourage mixing of refrigerants during the transition era. A mixture of the two refrigerants has markedly different pressure-temperature properties than either one alone and will not work.
