Ah man im mad at myself for this one. ![Mad :mad: :mad:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I left the 3100 Honda psi power washer hooked up outside after I used it on a nice day (with intentions of using it the next day.....) - got busy and it froze for a couple weeks.
The plastic inlet hose attachment was also broken. I "thought" that was the worst of it - I have extra power washer for parts so I replaced the plastic inlet hose attachment than hooked water up to it but was already leaking just from the water pressure... once i started it the pump works but is BLOWING water out of a crack in the pump head hat case..... (Pictures haha) with little actual pressure in the wand. So I tried JB weld/waterweld/bluemagic/can't remember the name, I think it "could" of worked if I let it set longer inside, but it didn't and still blows water out of these areas.
Can I replace just this item that bolts onto the bottom of the pump...? What is the actual name of it?![Unsure :unsure: :unsure:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Can I try fixing this somehow or would replacement be the best bet?
Thanks for the feedback and information.![Folded hands :pray: 🙏](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f64f.png)
