Nasty engine oil leak
Northern Indiana
Customer brought this unit in, FH601V Kawasaki a touch over 1000 hours on a Deere zero turn. Starts and runs beautifully it just leaks oil. The under the blower housing was frightening. New crank seal and reseal the crankcase breather box and it should be good. I'm going to check the valve clearance while I have it too.
Is that one of the Kawasaki engine models that has a remote oil cooler mounted under/inside the cooling shroud?
