Seems Advance Auto is using Cardone remans again, I looked at a pair last week and left them in the store. Junk, absolute garbage, the castings were so badly corroded I question their safety, I removed the bleeders and was shocked, they drilled out broken bleeders and used a tapered tap instead of a bottoming tap to cut or clean the threads and damaged the seat.
One of the boots was damaged and no pin lube, one of the pins was corroded and sanded down. They need to stop selling this junk, even with % off codes its not woth the scrap metal price.
I went to Napa (I needed these that day no time to order and no dealer stock) They have a new supplier, the Napa stuff has been decent but these are well done, very well done.
The casting is a select casting, no corrosion pitting on the aluminum caliper and marked with a green dot to show its okay. 10.9 and anodized hardware, nice boots with what appears to be sylgide lube, nice piston finish with nice fitting boot, well painted before assembly and initialed with the person that did the work.
For $10 more retail than AA or AZ its light years ahead on quality. I got my usual discount and payed less the AA even with the code.
