I did a front brake job on my Buick yesterday - new rotors and pads - (the rear drums are getting done this weekend). All went fine until I tried to reinstall the drivers side caliper. The top caliper slide bolt wouldn't screw back into the caliper. It would make about 3 turns and then stop dead.
After some brake cleaner and rags, I got the threads cleaned up enough to discover there were no threads. The first 3 or 4 threads were fine and the rest were trashed save for the last two. Rather then go through finding a tap to fit it and screw with chasing out the threads in the hopes it would work, I just bought a remaned caliper ($35), which was fine since when I retracted the piston with a c-clamp the boot didn't accordion in smoothly on itself leaving part of it exposed above the rim of the piston and likely to get damaged by the back of the pad.
What in the heck would cause this. I mean I've seen my share of stripped threads but usually all of the threads are trashed not just the last few. The threads on the caliper slide bolt were fine and I reused it since it was much better quality then the replacement bolt that came with the new caliper. The bolt came out fine and took just as much effort as the others to get out. So what gives?
The brakes were serviced once before at 30,000 mi (car has 100k on it) so I assume my old mechanic possibly screwed it up, unless cast iron threads can somehow just trash themselves for no reason.
