There are plenty of reported cases not only on this forum but other forums I have visited throughout the years that have claimed frams basically self destructed and sent peices of the filter into the engine.
Also plenty of pictures here showing the cheap construction of the filter allowing it to collapse on itself. Basically allowing un filtered oil to go into your engine all the time because its stuck open.
I have personally encountered a distorted fram oil filter that was for my pontiac. This was manny years ago when they had the Allied Signal stamp and not the honneywell one.
I used to use fram filters religiously untill I found all this on this web not only here but many other sites and forums. I find that even 3 dollars is too expensive for a shoddy filter. I can get a ST for less and IMO it is better construction.
But I will admit fram makes good air filters, fuel, tranny filters, and other products that are quality. Even the Xtendedguard filter is something I would run if I ever did synthetics.
