Yeah, it's now M22x1.5
Part Number: 57899
UPC Number: 765809578999
Principal Application: Various Dodge, Chrysler, Jeep (08-10)
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.740
Outer Diameter Top: 3.675
Outer Diameter Bottom: Closed
Thread Size: 22X1.5 MM 6-H
By-Pass Valve Setting-PSI: 16
Anti-Drain Back Valve: Yes
Burst Pressure-PSI: 275
Nominal Micron Rating: 21
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.815 2.480 0.175
They don't give the multipass spec's ..it's 21um nominal.
