Well pretty much like every other 500 to 800hr oil filter off a Kubota diesel flood light.
What is the factory OCI? I’m guessing it has the D1005?Well pretty much like every other 500 to 800hr oil filter off a Kubota diesel flood light.
Show us kore pictures and can you lay out the media?Well pretty much like every other 500 to 800hr oil filter off a Kubota diesel flood light.
I wish I knew if it went into bypass.I'm curious if the filter has any indication that it went into bypass? How does the loading look in the media?
Did the oil get changed during the filter interval, of was it also at 990 hours?
It's gone. There really wasn't anything inside pleats, a tiny bit of sludge is my guess and I had to hunt for it.Show us kore pictures and can you lay out the media?
Thank You
Right before I started working there they had a Cummins 5.9 that was running very poorly. When they went to change the oil they had to poke a wire into the oil drain hole to get oil to drain. That engine got changed. Don't know the hours on the oil.While I get the science on new equipment what is so neat to me is the use of modern oil in old engines. We are now changing at our convenience and running 10 times the oci as when they were new and really cant tell any difference and done have the sludge would have been found in them back in the day, that was common and now never unless there is a real fault. Even old dirty oil is simply dirty.
