Originally Posted By: ZeeOSix
... I think the smart thing to do now is lay off of XOM, they might just see this nonsense and sue him.
Yep, especially based on the used oil analysis results and the whole messed up path he's taken to try and get to the bottom of this fiasco. As I've said a few times, he should have been talking directly to Mobil a long time ago instead of doing "experiments" and trying to clean up the engine for weeks on end.
As I said before, I did call XOM from the beginning. They said most likely it was water/coolant contamination.(blown head gasket would be automatically my fault, and nothing short of major engine work) So that when I decided to send it in for used oil analysis. My experiments is external to the engine at this point. It was a waiting game for used oil analysis and the mechanic, so testing what would dissolve the sludge does not affect anything.
Posting for mechanic advice on reddit as there were several post of people having simile problems there. I did not blast XOM at all there. Just stated what I used.
Originally Posted By: Rocky123
Mobil 1 Extended Performance 5 Qt has a foil seal and the tamper proof plastic cap; quarts just have the tamper proof cap. The ones I buy.
Correct. I see both of those on mine. If it was previously open I would not use the oil.
Originally Posted By: tig1
This is a scam by the OP from the beginning. IMMHO. Wonder if he sells oil for someone?
I am sorry you still feel this way about me. The internet sucks because there are lots of evil people out there. I can not prove anything past this computer screen and that sucks. I understand you would be skeptical of the craziest oil event ever seen (at least the craziest I have seen) I wanted to share here because I wanted to see if anyone had this experience and what I can do about it. I never imagined someone could have tampered with the bottle until you guys mentioned it.
I think some of you are offended because of XOM brand loyalty. (heck I do too, used M1 for a long time now.) and it sounds like you would rather me not post or update.
