My own 2 cents on the Golden GC
Allentown, PA
Well, after what I thought was a stupid thing, I dumped out the green GC and filled up with the new Golden GC. I am no scientist, but your average car guy. I noticed only one major difference between the two. My car would make this humming noise after I turned it off while running the green GC. I was told this this was a secondary coolant pump in my 1.8T GLI circulating the coolant. Well, after the switch, the car does not make that sound. It still runs whisper quiet and very smooth. I am wondering why they changed from green to gold?
NJ
GF-4 is why they changed. If the base oil is the same, people can probably relax.
MD
That's weird.Maybe the secondary water pump is on the way out(common VW problem)?
Easton, PA
quote:
Originally posted by brianpavlovic: Well, after what I thought was a stupid thing, I dumped out the green GC and filled up with the new Golden GC. I am no scientist, but your average car guy. I noticed only one major difference between the two. My car would make this humming noise after I turned it off while running the green GC. I was told this this was a secondary coolant pump in my 1.8T GLI circulating the coolant. Well, after the switch, the car does not make that sound. It still runs whisper quiet and very smooth. I am wondering why they changed from green to gold?
Unless they changed something 1.8t don't have a secondary water pump only VR6's do as well as an auxillary radiator where the intercooler is hidden in the wheel well. What year?
MSP 'burbs, MN
quote:
Originally posted by Thermo1223: Unless they changed something 1.8t don't have a secondary water pump only VR6's do as well as an auxillary radiator where the intercooler is hidden in the wheel well. What year?
Brian has a 2005 Jetta GLI 1.8T based on info he gave in another thread.
Texas Hill Country
I also noticed an oil temp change switching back and forth from GC to Amsoil....I wonder if this is related....the temprature specifics of the GC that is.....(it's early and I havent had my coffee:))
NJ
I think what we have here is Gold (SLX) and the Green (SLX Longtec) or vice versa.
Indiana (IN)
GC most closely matches the Technical Specifications of the Castrol Formula SLX 0W-30. From the Castrol UK site: Castrol Formula SLX LongTec http://www.castrol.com/castrol/productdetailmin.do?categoryId=9003648&contentId=7006715 Technical Specifications SAE 0W-30 API SL/CF ACEA A3/B3/B4 BMW Longlife-01 MB 229.3 229.5 Opel/Vauxhall GM-LL-A-025 GM-LL-B-025 VW 502.00/503.01/505.00 Castrol Formula SLX 0W-30 http://www.castrol.com/castrol/productdetailmin.do?categoryId=82915273&contentId=6030498 Technical Specifications SAE 0W-30 ACEA A3/B3/B4 API SL/CF Mercedez-Benz MB 229.3 Volksagen VW 502.00, VW 505.00 & VW 503.01 Approved as BMW Longlife-01 Oil I wish we could get the RS 0w-40 too. http://www.castrol.com/castrol/productdetailmin.do?categoryId=82915275&contentId=6008717 SAE 0W-40 ACEA A3/B3/B4 API SL/CF Mercedes-Benz MB 229.1 VW 505.00 and VW 502.00 BMW Longlife-01 Oil Porsche - approved
Gone
quote:
Originally posted by vad: What's the difference between those two? (SLX vs SLX Longtec)
I am repeating info I sent in a PM to buster...it might be instructive (even though I start out in pretty much a "weenie fashion.") No, Buster, I don't know the technical differences execept for what is listed in the VOA that QuattroPete posted and that Stinky Peterson posted on GC (Gold Formula) that made them look like a similar formulation and which I believe contained elevated amounts of Mg. If you were to ask me to speculate, I believe SLX contains whatever changes to the 299.3 formula were needed to make it a 229.5 oil. I told buster that going to 229.5 might make it a thinner oil, but I have changed my mind and don't believe that necessarily to be the case. If GC is indeed LongTec I think both versions have had their color changed (from green to gold [actually they are no longer dyed]) as a distinguishing characteristic between the two. I think it will still be a powerfully performing oil. It makes no sense for Castrol to come up with a killer formula and then emasculate it, even in the name of longer OCIs.
