Hey guys. Background story: 1992 Chevy 5.0/305 TBI here. Previous OCIs by former owner were using whatever oil our local mechanics offer for cheap, i.e. CAM2 and other discount brand oils, except for the last previous oil that was Valvoline dino. There is noticeable sludge at least on the top-end when looking through the oil-filler cap/valve cover. I switched to PYB last week. Also, truck is a 5 speed manual.
My oil pressure for months since I got this truck has always been 30 psi. Start it up, it rises to 30, and maybe rises to 33 during driving/RPM increase, consistently. Yesterday night I noticed that at idle my oil pressure was dropping to about 16 psi, which is strange for this truck. Even when coasting downhill it was dropping from 30 to 16 as well. I have to tap the throttle (either at idle or while moving) to get the pressure to spike to 30 again, but then it drops back after a few seconds. Is that normal? Again, this truck has always held 30 psi regardless before last night.
Also last night I needed gas and went to Cumberland Farms instead of Mobil like I usually do. I noticed at the same time as my oil pressure issue that my truck was idling significantly rougher than usual. Idles with a vibration now similar to when a coil-pack fails. Bad gas? Maybe water contamination?
I had checked the oil yesterday too (it is completely full and no burning, leaking, or consumption issues here) and noticed that even after not even a whole week the oil is getting dirtier. Which means that it's doing it's job and dispersing contaminants and sludge - good. Could this Pennzoil already be removing some blockage in an oil passage or something thus causing my oil pressure fluctuation? Maybe this was just how it's actually supposed to be all along. Or maybe this seemingly bad gas is causing this rough idle, thus my idle isn't strong enough to keep the oil pump running fast enough to keep up?
Or maybe it's something completely different. Does anybody have any insight on this? I wanna hear any and all opinions because it seems really weird and sudden of a change for this vehicle.
Edit: Also I just thought of this... Could it be that my truck just got it's first dose of higher ethanol winter gas and just doesn't like it? It's an old engine after all, not really designed for that.
