My new favourite HDEO
sweden
Hows about this one- a HDEO syn Q8 T800
KVALITETSNIVÅ
• API CI-4/SL
• ACEA E7, E5, E3, B4, B3, A3
• MB 228.3, 229,1
• Volvo Drain Specification VDS-3
• MAN 3275
• Renault VI RLD-2
• Caterpillar ECF-1 & ECF-2
• MTU Type 2
• Mack EO-M Plus
• Cummins 20071,-72,-76, -77,-78
• Deutz DQC III-05
• Global DHD-1
TYPDATA
Densitet, 15°C, kg/m² 874
Viskositet, cSt
vid 40°C 90,5
vid 100°C 13,5
Viskositetsindex 150
Sulfataskhalt, vikt % 1,3
Flampunkt, °C 220
Lägsta flyttemperatur, °C -36
Lägsta pumpbarhetstemperatur, °C -28
TBN (bastal), mg KOH/g 10
Or this one, another Q8 but this is called T905
KVALITETSNIVÅ
• ACEA E7, E6, E4
• MAN M3477, M3277 för kontinuerlig
återregenereringsfälla (CRT)
• MB 228.51, 228.5
• MTU Typ 3 & MTU Typ 3.1
• Volvo VDS-3
• DAF HP-2
• Renault VI RXD
• Volvo CNG
• Renault RGD
• MAN 3271-1
• MB 226.9
• Deutz DQC III-05
TYPDATA
Densitet, 15°C, kg/m² 860
Viskositet, cSt
vid 40°C 95,7
vid 100°C 14,0
Viskositetsindex 149
Sulfataskhalt, vikt % 1,0
Flampunkt, °C 212
Lägsta flyttemperatur, °C -27
Lägsta pumpbarhetstemperatur, °C -24
Any comments on these? I use the first one in everything..
MB 228.51 & 228.5 are rigorous specs and the former spec. requires newer additive types (lower SAPS). I like the latter oil better based on specs met and having 1.0% ash rather than 1.3%.
Is there any good reason for using a lower sulfate ash oil?
I dont have any "modern" diesel in my stable, no cats or partikel filters etc.
I use the oil in:
My Ford 4000 farmtraktor.
Durango 5.9
hyundai atos 1.0
Motorcykle, fourwheeler,lawn mover, moped etc.
Ie everything thats fourstroked.
Some reasons for lower ash oils are:
1. Some engines don't tolerate higher ash oils well in the piston grooves and piston ring area (it's hard to say which ones other than by what the manufacturer recommends). They are sensitive to ash buildup there which can increase oil consumption.
2. Ash is abrasive and can increase wear relative to an oil with less ash that otherwise is similar
3. The much spoken of emission friendliness because ash can build up in cats and the phosphorous chemically deactivates the cat material. Sulfur is bad too but I forget why (sorry).
