Rotella or some oil with decent levels of ZDDP (not mainstream API SN oil). I'd probably use Brad Penn "grade 1" but Rotella is easier to get and should also be good.
Viscosity: On an old engine you can't be sure what the bearing clearances are like. Start with what was specified by the mfg, but if oil pressure looks low go up from there.
If you need 15w40, I wouldn't worry about it. If you find yourself needing 20w50, then use it but plan on an eventual engine overhaul.
