userfriendly
If we look at other hydraulic systems than in an automotive engine, there is typically a pump
that has a larger capacity that is required by the system.
In addition to the pump, there a series of checks and valves built into the hydraulic
system to control the direction of flow, volume and pressure.
We are all familiar with the engine pump by-pass and filter by-pass valves, but other
means of fluid control are available to the engine designer.
One trick is to drill small holes in pipe plugs and install them at the end of oil galleries.
Back to Newton; A fluid in motion will want to stay in motion.
That hole in the pipe plug will cut the "response time" of the fluid
for immediate lubrication in a changing environment.
Changing a T-fitting to a Y-fitting improves engine oil distribution.
Pressure relief valves may be added in other locations in an engine
besides at the pump and filter.
