OK. Finally got my 91 4Runner from the mechanic. A friend of mine was tired of repairing it, and gave it to me with a blown head gasket. I tried to help her get it fixed at a good price, but she finally didn't want to put more money in it. Since I was starting at $0.00, I didn't mind so much. Here's the itemization I got from the mechanic:
-used engine 3.0 L 3VZE
-water pump
-timing belt
-idler bearing
-fan
-hoses
-oil cooler
-oil (Mobil Super 5000)
-oil filter
-air filter box (the original was broken)
-MAV
-intake plenum gasket
-air intake elbow
-intake gasket
-spark plugs
-rear main seal
-atf
-plug wires
-distributor cap
-mls head gaskets
-valve adjustment (3 shims)
-misc bolts
-plenum stabilizer
-motor lift hooks
-crankshaft pulley
-belts alt ps ac
-fan shroud
-fuel dampener
-knock sensor wire
-2 fuel injectors
-pcv hose
-ac receiver drier/accumulator
-hi pressure line
-o rings
-catalytic convertor
-smog check
Then, right after I got it, the starter quit. I replaced that myself.
If it works for a while, I'm going to call this a pretty good deal. Body is mostly straight, almost no rust, transmission feels good, engine runs smooth and quiet. There are, of course, a few details left to work on, but I asked him for a functional vehicle, and if I had an unlimited budget, I wouldn't be fixing up a 1991 4Runner.
This odyssey began when I asked a friend of mine why she wasn't driving her 4Runner. She told me about the head gasket, and I thought about maybe doing it for her, but I don't really have the time right now. I know a pretty inexpensive mechanic who does good work, and he said he could do it for around $1000. I got the two of them together, but she then found a nice Ford Expedition and bought it. So she gave me the 4Runner.
The mechanic I used for the work was advertising a used 3vze on craigslist for $690. Turns out he specializes in 4Runners.
If there's any interest, I can post a pic or two.
-water pump
-timing belt
-idler bearing
-fan
-hoses
-oil cooler
-oil filter
-MAV
-air intake elbow
-intake gasket
-spark plugs
-rear main seal
-atf
-plug wires
-distributor cap
-mls head gaskets
-misc bolts
-plenum stabilizer
-motor lift hooks
-crankshaft pulley
-belts alt ps ac
-fan shroud
-fuel dampener
-knock sensor wire
-2 fuel injectors
-pcv hose
-hi pressure line
-o rings
-smog check
