The
The 3 an Y share the same drivetrain and battery so it gets thrown down by journalists as the bench mark for what the drivetrain is capable of.
I didnt mention MPGE (and I dont care about it) at all because I didn't want to get bogged down with it, or care how it compares to an ICE car.
KWH per 100 miles is a better standard to judge electric vs electric.
When you speak of differences in the chart - which differences are you talking about? The results?
To the Y and Id4 perhaps, but model 3 was included in the text I cited.
The thing with 100kWh or 75kWh usable is I dont know how that is defined, and each vendor may change that slightly by controls.
I think that MPGe is essentially kWh/100mi and then correlated to electrons by saying that there is some amount of Wh/gallon of gasoline. But the exact correlation, since the efficiency of conversion from a gallon of gas to a useable Wh of electricity is variable.
Id prefer, to compare apples to apples, without cheating, to just see the straightup Wh/mile at low speed and high speed drive cycles. Noted that the graphic you show gives those numbers, but the question remains of why are they different?
