Thanks, I will check with my local tractor supply. Never thought about them! Thanks again.Doubt you will find 85-90, but 80-90 GL4 can be found at tractor supply.
85W90 GL4 Gear Oil (1 Liter) - Liqui Moly 20016
85W90 GL4 Gear Oil (1 Liter) - Liqui Moly 20016www.fcpeuro.com
Thanks!85W90 GL4 Gear Oil (1 Liter) - Liqui Moly 20016
Thank youRavenol MZG
I used that in 2 stroke dirt bike transmissions back in the day.Mobil 1 Delvac 50
PdsDetailsPage
Mobil Delvac Synthetic Transmission Fluid 50 is a fully synthetic, manual transmission lubricant engineered to meet the most demanding extended drain and OEM warranty requirementswww.mobil.com
The Triax looks a little thin, I suggest Ultra Lube GL-4 75W-90 GL-4
U1P-Gear SAE 75W-90 Synthetic Gear Oil, API GL-4
Ultra1Plus™ SAE 75W-90 Synthetic Gear Oil, API GL-4 is highly shear stable while also resisting rust, oxidation, foaming, and varnish.ultra1plus.com
