What happens to the viscosity when you mix a single grade into a multigrade? I normally run 15w40 Rotella in my '83 Goldwing, however this past week temps have been in the 100's and I would be more comfortable if I were running a 20w50. If I were to add 25% 50wt Rotella to the 15w40 or say the 5w40 Rotella synthetic the 'winter' rating would surely increase, but what would happen the viscosity at 100c? Would the viscosity modifiers in the 15w40 or 5w40 increase the brew above a 40wt being the the baseline viscosity has increased? Is it possible to brew something close to a 20w50 out of the available Rotella weights?
