The back of the muffler shield fell down onto the muffler after the hole in it enlarged itself and was now larger than the nut and washer holding it. The nut and washer are attached to a stud or bolt coming down from under body. (I would guess its a #10 screw size at best, yes its probably metric.) The stud is maybe 3/4" long and of course rusty.
The shield can also shift a little sideways and rub against the drive shaft to I now have a 6" section of the drive shaft that is highly polished.
I figure I got one chance to get the nut off (or snap the stud) so I will spray it every day with PB Blaster for several days. Once I get the nut off, then just use a larger washer and I should be all set.
Other suggestions?
Could someone at a shop hit it with a torch and give it a better chance of coming off or is it too close to the under body or too small a size for a torch to help?
Other suggestions?
