So I have a 2 gig player and it won't fit all 555 Johnny Winter songs I have amassed (some are repeats, like probably a dozen plus different performances of Johnny B Goode, each one worthy in it's own right). (Did I mention I have two more Johnnyh Winter CDs on order?) What I need is a 4 gig player that is easy on batteries, will run a shuffle without replacement (to borrow from statistics, that means won't play same song twice until it is through the whole folder), and will keep it's place when shut off.
I found battery life is better if the display is not always on or even not accessed very much. My Phillips 2 gig goes 36 hours without accessing the display which is blank when off, but my Centon 4 gig has an always on display (not always lit though, but you can see it) and it eats a battery probably every 12 hours--real bad.
I would go with the rechargable type mp3 player if it had a decent run time, say minimum 16 hours, on charges. Somehow I think I am stuck with batteries. I can get a GPX 2 gig with expansion SD slot, so maybe that is the way to go. Not sure it has all the features I want though, and it is a rechargable.
Any suggestions. Oh did I mention I don't want to spend a ton of money, may go $50 but not much over. Ipod has a really tiny shuffle that comes in 2 gig, if had 4 gig and good battery life, might be the way to go, but I DON'T want to fool around with converting files to the IPOD format. I want to drag and drop wma files and be done with it.
It used to be oil obsession--not this.
