That's what I thought. Check out the brakes on my GL1800 ABS(Modulators not shown);
The front brake lever applies the front brakes initially. 1 puck on the left, 2 pucks on the right. The left front caliper applies pressure to the secondary master cylinder as it tries to rotate with the disc. This in turn applies pressure to the anti dive unit and 2 of the 3 pucks on the rear brake.
The rear brake application applies 1 puck on the right front, 2 pucks on the left front and initially 1 puck on the rear. The anti dive is then also activated and then the other two rear pucks via the proportioning valve when the left front caliper activates the secondary master cylinder.
Apply both front and rear brakes and you get the max braking effect from all pucks on all discs.
There are also delay valves and proportioning valves along with ABS modulators (if fitted), in the system.
