Owning a Ford, and using the factory OEM Motorcraft Synthetic Blend oil, seems like a solid choice.
But, synthetic blend oil is typically made up of 80% conventional oil, which will leave deposits in higher heat situations (like engines with twin turbos or engines with long timing chains that are hard on oil).
My biggest fear with those engines is the long timing chains and preventing them from wearing out.
For some reason, Ford timing chains seem to wear out quicker than a rubber timing belt would have lasted.
Since the timing chain is deep inside the engine, labor is very high to replace a worn timing chain on ecoboost engines.
https://www.f150forum.com/f118/timing-chain-replacement-cost-563111/
Using a full saps Euro 5w30 (Acea A3/B4) with high levels of anti-wear additives phosphorous and zinc could prevent more wear and help the timing chain last longer.
