Motorcraft Oil Filters
NC
Can someone tell who make motorcraft F820 filters, I went to advantage auto and open box's of different oil filters and looked at the bottom of the base plate and Mobil 1 filters look like the factory filter that came off my truck, but not like the replacement 820MC that I put on it?
1. This is in the wrong section.
2. The Motorcraft filters are made by Purolator
3. The OEM filters for Ford vehicles are made by Champion Labs, the same folks who make the Mobil 1 filter.
To be clear that part number is made by Purolator most of the time. Ford uses whoever is the cheapest that will build to their specification. Also they don't tell us parts people who the vendors are for most of the parts, although we can figure it out by where they ship from or where they go when replaced parts are called back under the warranty program.
Originally Posted By: YANCEY
Can someone tell who make motorcraft F820 filters.
From last night's discussion...
Sorry I posted in wrong place. But thanks for the info. Where is the info about flow on filters? I would like to know what the best filter for my 5.4L or just stay with MC 820?
Please correct the OP on where to ask the question about oil filters. I would like to know as well because this is the OIL FILTER section!
I'd stay with the Motorcraft FL-820S.
There IS no "best filter". M1 and AMSOIL are considered to be top notch, but are expensive. Purolator Classics are inexpensive and highly regarded as good basic filters, but are lacking some of the more desirable features such as a silicone ADBV, threaded-end bypass, ...and so on.
I think the general consensus is that including all the factors, such as price, availability, features, build quality, etc. the Motorcraft FL820S is considered the best overall "choice" for Ford products.
Considering he mentioned that he can get the 820S racing filter for $10.00, I'd say that's the "best" filter for this application. That's a good price on it, too. I wouldn't say it's the best value, mind you--but I would say it's the best.
Will it make a difference in the long-term performance of the engine? Probably not. But then again the same could be said for a Fram Orange can..
It flows better, filters more finely, holds more contaminants and is better-constructed than the regular 820S. Plus, the bypass is in the base as specified by Ford. So, if you're looking for the "best" filter in this application, the Racing 820S is probably the one.
Here's one cut open: LINK
The factory installed filters are made by Champion, like the Mobil 1 is, the Motorcraft replacements are made by Purolator. Been mentioned many times on here, and they have been doing it for many years this way.
Well reading more carefully I see someone else already said this.
