Motorcraft FL2121 10k 275 hours
Edmonton, Alberta, Canada
This is from my personal truck. 2018 F150 5.0 with 125k kms. Interval was 275 hours, almost 10000 kms (6000 miles) and down to 3% remaining on the oil life monitor and 6 months of use. I was going to do a longer interval this time and change the filter half way but I had some valve cover leaks so I cut it a little shorter than I wanted. Oil used was liqui moly molygen 5w50 which I’m using again this interval but with a premium guard jobber filter.
I’ve wondered what the differences are between these Champ made Ecore MC filters and the Champ made AC Delco filters, other than some of the ACDs going to metal endcaps(?) Otherwise they seem identical.
yes I just cut one recently and posted it from my friends whippled coyote. It’s posted here to show the difference. Very similar other than the end caps. I feel like the motorcraft held up better then the ac delco though.
Looks like you have slow speed roads or idle a lot? That's a good bit of hours for 10,000 kms. Filter held up well though & I'd assume the PG should do the same. Coyote!
