Motorcraft FL-910, poor filtration?
Good luck with that, 'Busa. The last time I emailed Purolator, all they would do is confirm that they do manufacture Motorcraft filters, but all other info was proprietary and belongs to Ford so I would have to ask them. I gave up at that point.
Originally Posted By: panthermike
I see at Pepboys I can get the Purolator Classic for the same price as the Motorcraft at WM and the Pureone is 2.00 more. What do you guys think?
PureOne...gives the best 'bang' for the buck...
I believe your vehicle calls for a Puro PureOne PA 10241, or if you have room for a longer filter , the PA 20195 willl also fit.
_____________________________________
2003 Ford Focus SE (2.3L) / 83K
Valvoline MaxLife Syn 5w30 / OCI 7000+/-
Purolator PureOne PA 10241
PureONE use the "PL" prefix on the p/n. So a PureONE 20195 should be a PL20195.
The Classic uses the "L" prefix on the p/n. So a Classic 20195 should be a L20195.
