does anyone know if this filter will fit on a 1.6 and 2.0 liter kia engines. i have always used ford filters on other cars. with good results and would like to stick with them, but i am open to suggestions. Thanks.
Originally Posted By: dnewton3
check out www.wixfilters.com and you can research all the characteristics there.
+1 Check thread size, gasket size, and bypass pressure. If they are all close and you have room for it, go for it. If the gasket size is different, measure your mounting. A smaller gasket than stock would work on my truck, but not a larger one.
