Motorcraft and seal under the cap
The Tropics of Antartica
Has anyone using the Motorcraft seen that the 5w30 uses a foil type seal under the cap on the bottle where-as the 10w30 does not ?
How about you 5w-20 Motorcraft users , does it have a seal under the bottle cap ?
Any ideas why the 5w30 is sealed ? I think I know but it's only a guess . Waiting to see if the 5w-20 is sealed .
I hate those seals. Always afraid a piece of the seal (which seems to only come off in pieces) will end up in the bottle and then in my engine.
Also, makes it hard to sniff the oil in the store.
[ March 11, 2004, 12:10 AM: Message edited by: TallPaul ]
Both Motorcraft 5w20 and Conoco Hydroclear 5w20 bottles come with the seal. If I remember right, the bottle does not have a cap that breaks when you open it - thus the use of the foil.
Two of my last four 10-30's that I bought had the seal and the others had the break-away cap. Seems to rip in one piece though. Maybe the foil indicates newer stock and Moly!?
[ March 11, 2004, 06:29 AM: Message edited by: Chris ]
We will find out soon . I sent in a new stock 5w30 sample last week . I wish I had sent a sample of the 5w-20 as well but I don't use it so ... I didn't.
Two used oil analysis in Ford engines that do not use a coated piston indicate moly is now used in the Motorcraft 5w-20 but it's too soon to tell .
I bought 6 quarts of MC 5W-20 3 weeks ago at Walmart. Two of the quarts had no seals and break-away ring caps, the other 4 had the foil. Caps were the same color and the rest of the bottle was identical.
If they continue putting these foil seals on them, going to have obtain an funnel with a filter.
Through 6 oil changes (36 quarts) so far with Motorcraft 5w20, all have had the breakaway rings. No foil caps. I have been buying by the case at AutoZone.
