motorcraft 910 and neons?
stamford, CT
hi all! i have a 1995 plymouth neon, SOHC, 2.0 liter car. i was wondering, if i can use a motorcraft 910 oil filter on it? ive always wanted to try motorcraft, so thats why i ask. the 910 is the same size as the oil filters form fram, purolator, ect for my car. jsut curious to know, just in case.
Hmm ..what's wrong with the FL300? That fits my son's 96
There's no problem fitting either.
(in Wix for comparison)
(FL300 size)
Part Number: 51068
UPC Number: 765809510685
Principal Application: Agco Tractors, Chrysler (70-91), Ford/Mercury (83-97), Kubota Engines, Land Rover (95-04), Toyota (68-90)
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.338
Outer Diameter Top: 3.660
Outer Diameter Bottom: Closed
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=10/26
Burst Pressure-PSI: 275
Max Flow Rate: 7-9 GPM
Nominal Micro Rating: 19
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.834 2.462 0.200
(FL910 size)
Part Number: 51215
UPC Number: 765809512153
Principal Application: Harley-Davidson Motorcycles, Ford, Mazda (03-06) (For chrome version, use 51225)
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.404
Outer Diameter Top: 2.921
Thread Size: 3/4-16
Burst Pressure-PSI: 325
Nominal Micro Rating: 24
Gasket Diameters
Attached 2.734 2.430 0.226
The OD on the gasket appears slightly smaller ..but not of much consequence, IMO.
You can go bigger (FL1A) but it hangs jeeest a bit below the pan
