Trop-Artic Synthetic Blend 5W-20, it's $1.68 at WM and pretty much the same as MC 5w20
"The next generation of all-weather protection. The new GF-4 standards require levels of fuel efficiency and emissions control that will force oil manufacturers to make critical decisions about how they will achieve the desires results. At Phillips 66 our decision has already been made. While some may attempt to continue to squeeze performance out of conventional mineral oils we have decided to go a different route now our standard oil is a synthetic blend.
Synthetic blends offer a number of performance benefits over conventional oils and make it possible to meet and exceed the GF-4 requirements without having to make major sacrifices in other performances areas. Benefits include better hot and cold protection, faster lubrication at start up, improved fuel economy reduction of emissions and cleaner engines with reduced wear.
API SM,SL, Energy Conserving, ILSAC GF-4, DaimlerChyrsler MS-9395M, MS-6395L, Ford WSS-M2C929-A(SAE 5w30), WSS-M2C930-A (5W-20), GM 6094M, GM 9986231 (SAE 5w30) GM 9986202 (SAE 5W-20)"
