Depends.
What spec does the heavy truck engine in question require versus what M1 15W-50 offers?
If the engine requires only an API CF oil, then the M1 15W-50 would probably do well in it.
This oil would be plenty thick enough.
It might not have adequate dispersants to deal with the soot loads some diesels impose on the oil over the typical drain interval.
This oil also has plenty of TBN, but that is less important now with ULSD universal in this country.
XOM does offer the already mentioned Delvac 1, which is a bit of a unicorn, as well as M1 TDT, either of which might be better suited to use in a large diesel.
