- Joined
- Sep 28, 2002
- Messages
- 39,793
P
You're the first person, to my knowledge, to propose this type of return method. It's quite compelling (READ: I like the novel approach
) . I think if you ask Ralph ..he'll confirm this. You and I share one commonality ..we both tend to envision situations that never occured to others. You don't know how many times I had the engineers at my old job scratching their heads grasping for "what if" answers
I don't know your comprehension level of flows/pressures and whatnot ..so forgive me if I get fundamental or redundant.
Although the pressure relief valve on the premacool will open @ 2psi ...that's not the limit it will see. That poppet is alot smaller than the added area of the holes in your ff filter. I venture to say that if you put two pressure guages tapped across the premcool (one in each port) ..you would typically see more than 2psi diff between them ...depending on oil pump output (rpms).
This restrictor (the relief valve) is only there to create that differential because you're returning it to the point immmediately after it. That is, it inserts a resistance to compell flow through the bypass media. I assert that this may be unecessary in your case since the FULL FLOW FILTER will do this SAME FUNCTION since you are BYPASSING IT ...just like you BYPASS the relief valve in the permacool. That is, the ff becomes the resistance to compell flow. I would think that 2 psi would be realized across a ff filter, even at operating temps.
If you leave the relief valve totally intact as it comes from Permacool ..you will be INCREASING the total resistance to the pressure port via the ff fliter pathway.
That is:
Permacool relief port resistance (variable depending on flow/viscosity) + ff resistance (variable depending on flow/viscosity/bypass valve setting) in parallel to the M30 bypass filter ..both on their way to the sender port.
In other words ...starting off ..you will have the MAX flow through the M30. The total flow (assuming the pressure relief limit for the OIL PUMP is not reached at any time) will be unchanged to the pressure sender port ..they both reconverge there. If "too much flow" is occuring ...it will be here. The pressure drop across both the relief valve and the ff is greater than the relief valve alone.
P ..thank you for this stimulating topic to ponder here. I hope that you see I'm not arguing with either you or Ralph ...you've added a new spice to the sauce and I just like the flavor of it ..so to speak. If I had thought of it (darn it ..you beat me to some novel approach to something - my ® trademark
) these are the aspects of it that I'd ponder ...at length (visions of that poster that depicts philosophers and theologians looking at a box with a big "N" on it with the caption, "Is "nothing" sacred?")
If I had the time ...and really wanted to get the "fat" on this, I'd install the permacool sandwich "straight up" and take pressure readings across the relief valve (plugging one at a time and rigging a gauge to each) over the full spectrum of engine temps and rpms. This would give me the max and min resistance that the relief valve and ff present to oil flow. This would also give me (assuming you have a gauge output from the sender/sensor) any loss in pressure data that may occur. If the pressure at the sender was unchanged ...and I had at least 2psi differential (if that's the spec that Ralph says is "enough") during warm engine/2000 rpm, then that's where it would stay. If however warm/2000 rpm differential was substantially higher ...then I'd incrementally open the relief port. If I have my 2-4 psi differential and my M30 didn't get warm ..I'd remove the restrictor.
Not matter which way you go on it, good luck!!! and let us know what happens with this novel return modality.
That is:
